what is the convertor stall and what gears are you running? cam card says 3000 recommended and I would run a 391/410 gear. 107.5 isn't a big deal but I personally would retard it 2 degrees.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
