What kind of power can a small block handle? I have a 1970 340 standard bore and a 1977 360 .040 over both ready to be used if either one of them can handle boost ok. If not I may buy a new block if I go the wedge route. Just not sure what they can handle.
A simple, BUT EFFECTIVE stroker setup on a 340/360 motor (yeiding in the 420-426) cube range should be streetable enough to drive every day BUT run the 11-11.5 bracket in a 3500+ weight package w/4.10's. Carb, compression and converter stall depending.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
