Do not leave epoxy exposed to oil, it will eventually swell and dislodge/debond. Why would you want to use an epoxy with a vibrating oil pump.
Astrobuf
Vibrating oil pump? It would seem If you have harmonics that severe his pick up would be the least of his worries.
An oil pump is a bit like a tuning fork. The pickup is flexible and has mass on the end. Take a hammer and bang on an oil pump, you'll see the pickup wiggle, especially at its resonant frequency. The engine firing pattern does the hammering.
Astrobuf
Hmmm! You sure sound convincing.
I have broke off the entire oil pump from a BB chevy more than once from tire shake. They make a brace to keep it from happening, I fixed it for good by going with a belt driven external pump.
When you start making power you learn about these things.
I agree with the tire shake issue, That is an effect from outside the engine. Im just not sure about the comparison of Banging on the case of a oil pump with a Hammer and resonant Harmonics from an oil pump operating as intended.
Trust me, I'm a Mechanical Engineer with an extensive background in structural mechanics ;p
So, are you really a Rocket Scientist?
