Do not leave epoxy exposed to oil, it will eventually swell and dislodge/debond. Why would you want to use an epoxy with a vibrating oil pump.
Astrobuf
Vibrating oil pump? It would seem If you have harmonics that severe his pick up would be the least of his worries.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
