I like to go in as shallow as possible.
John, In my dragster, I was taught by a good racer to use the slow backup procedure and just turn the lights on and then back off while backing up very slowly. Sitting there with no lights on it doesn’t take much movement to turn on the top bulb and makes staging the long dragsters much easier. At least I though so.
From what you wrote, I take it the racer in question is backing up and cycles the lower bulb and then sits there and leaves the top bulb on; and driving right into stage when the opponent turns on their top bulb. As you said nothing illegal there, but certainly causes a rush for the opponent.
Bob Spleic
Yes this is what they are doing. Both lights are never off.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.42@138.27
