All failures were on the load side. The internal race is still in place best I can tell at this time. Spring pressure was at 120 at time of failure. I since replaced the springs but have yet to run the motor. Two valve springs had broken on the inner spring besides having weakened across the board which is why I replaced the valve springs. All these findings occurred while swapping in different pistons for added compression.
I wonder if it went into coil bind .. that would
account for both the springs and the rockers
