if you are going to make something you find at the junkyard work i would go with a 94 dakota pedal setup--then use the 90,s chev firewall bolt in adapter that knotches the clutch master into it (2 bolts)----if i was gonna buy something that works on everything i would go to speedway and buy a circle track brake and clutch setup....bob
