going down the road it sits just to the left of the middle between C and H. If i exit and idle at the light for a minute or two it creeps over and touches the H , then I start scrambling to get moving and it cools down once I get moving.
If you have a fan clutch it is time to replace it. It's not working anymore.
Note if you have a 4 core the new replacement units are too tall (will hit the radiator) to put in. Use a Hayden 3665 or a 2765. I think it was $39
here are some pics, let , me know what you think.
