It's really no problem....it's just that the situation hasn't changed from several months ago.
The block isn't sold bare any longer, so it has to be a short block assy. As painful as that may be, at least there are about a dozen of them readily available.
Same with heads, it is no problem getting them, there are about a dozen of each part number available. But they are not sold bare. For anything other than a stocker the Eagle and Apache heads seem to have taken over.
I'm confused. R U taking about the 6.1 block only comes as a short block?
If yes do you have a part #?
If this is true I don't understand why Fiat sold so many bare 6.1 block.
According to INDY they bought almost all of them at a really cheap price.
Even if they had really bad core shift why?
Obviously the short block are for warranty?
