Like Mike said, you will need to install the hump. However, if you return the car back to automatic, just change the top plate, and run a shifter cable instead of the mechanical linkage.
Gene,...after he installs his Keisler TKO, and hits the streets,......he'll be saying "automatic"?....whats that?
