Jackson
Bad news!....you'll have to put in a 4spd hump,and buy a new carpet and I fully recommend cutting any part of the floor that interferes with attaining a proper driveline angle, the Keisler E body shifter will "appear" were a factory 4 spd pistol grip would,.....I'd recommend, cutting the floor, hold off welding the 4 spd hump in, install the tranny and shifter,phase the driveline, you don't need a drive shaft for that, but you do need an inclination degree wheel.....begin by mesuring your rear pinion angle with the car on the ground, fully equipped as if you were going to drive it, then measure the transmisson, and adjust/ shim/ modify/ whatever to phase your driveline,or rear end.....then install the hump, based on shifter location (centered in hole), tack into place, seam seal, finish install
