Quote: I'm going to say its too lean. The same as when its not up to temp. I have had this problem with Eddy carbs before. More so on trucks... When under load they pop back. You can have the same effect when the choke is off and the engine has not completely warmed up. Lean pop...
I'd be looking for an intake/vacuum leak and then start going through the carb.
