Can't use that accel plug, it don't have enough reach.
Well they are working, but you think that be the issue??
Plugs are cheap so what do you all like to run??
These ACCEL C-Cut performance spark plugs produce a larger spark for more power at high rpms. They improve throttle response and fuel economy and reduce fouling. Their purified Alumina insulator prevents arcing, and their machine-rolled threads protect heads.
