That was not much help, guess you just needed to say something. It has a 1600-stall and can't make any power, was thinking 2200. Anyone have any real info to share??
Actually, that was the best sdvice you'll get but the term "factory converter" is little ambiguous...the stock factory 340 converter is an 11" high-stall and should stall at 2250-2450 behind a stock 340.
Yeah, the 600-700 RPM increase in stall will probably get about 50-75ft/lbs deeper into the powerband, which should help "launch". I don't agree with swapping in deep gears and killing overall driveability for an occasional better launch. 3.55's would be nice, but I don't think worth the cost unless I was buying a gear anyways. And all this is baised on a 28" tire - taller tires would require more gear.
Free advice and worth every penny... Factory trained Slinky rewinder.........
