Also id like to know what the actual duration and .050 numbers are for this cam as they seem to change every year on these trucks.
You might want to purchase a "degree wheel" and dial indicator w/magnetic stand. Checking the duration at .050 would be very easy then. Have done it with a few cams and it only takes a few minutes!
I have one but the motor is apart for cleaning right now so i cant check it myself, just wanted to see if anyone else had the same cam.
