Most of the small block strokers are running low 30's I run mine at 32*
They apparently don't like a lot of timing. You said you run 1/8 mile then posted times in the 11's, I have to assume those are 1/4 times?
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
