put smaller jets in the carb. Keep going until the car loses MPH. Then go up two numbers.
Same thing with timing keep dailing it up til it slows down then go back two numbers.
I can't say this enough MPH is HP. ET is not. Get your MPH by tuning the engine. Then work on the suspension to get the best short times. If footbraking you can play with squirters and timing curves.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
