I run alky injection and will never run anything else after running it. My maintenance is the same as before. I run a star vacuum pump and the oil stays crystal clear. I also run rons toilets. Only my pump and injectors are from them and everything else is enderle. If you do decide to run injection instead of a carb I agree with the others, have it setup by someone in the know.
