Many years ago I built a 383 with 12.5 comp and used an Isky hyd cam with .500 lift and 300 degrees of duration - installed straight up. It wasn't the most "street friendly" cam but it had no problem running the power brakes. I ran a 4-speed with a 3.23 gear behind it.
