Sure I ran huge cams with my power brakes and that is just a baby. Run a 7/8" master cylinder degree the cam in at 102 and have the in gear idle at about 1000 and you will be fine. Running a 509 or 484 is all about degreeing them in right 3000 stall full advance by 1500 (or less) and 1000 idle in gear.
