Quote:Have you considered using Comp Cams Ultra Pro Magnum™ Rocker Arms? Has anyone tried these with a large solid flat tappet or hydraulic/solid roller cam? They look like a high quality part, and they come bushed. Not cheap.http://www.compcams.com/ultrapromagnum/http://www.compperformancegroupstores.co...;Category_Code=http://www.compperformancegroupstores.co...;Category_Code=http://www.summitracing.com/parts/cca-1621-16 Big Block Moparhttp://www.summitracing.com/parts/cca-1622-16 Small Block Mopar
