If you have headers make sure the cable is away from the tubes it will melt. I used a hose that just fit the outside diameter of the cable, split it and use it as protection.
Learned that the hard way
I have used fuel hose UNCUT.slipped it over the cable with a small hose clamp on the bottom side to keep it from leaking.That's for after it get's burnt and starts to leak
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
