Quote: Mr. Yuck. Do you want mustard or catsup with that crow?
Still at Milan. 5th pass, Zero boost launch, 11.30 @ 122 so far on only 8psi. Time to turn up the launch and the boost.
More later.
good running! I'm glad I was wrong. Don't blow it up.
Yuck... isnt your car pressurized(boost)
old one was, this one is just a 11:1 6-pack 440. Next one is going to be a 500ci wedge w/ 8-10lbs of boost. Boost is the way to go for sure. Especailly if you drive the car and from the track like me. I'm just not sure if I want to go turbo or centrif supercharger.
