God am I glad all my old O.E.M. stuff works like it did when new and that old bird won't go over 190* under any circumstances.!!
You want restriction here is my grille.
That lower air dam helps create a higher pressure area in front of the grille and a lower pressure area behind the radiator. That forces more aire through the grille.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
