Can this be used with the Borgeson steering box?? Not sure what pitman arm is used on the mopar/borgeson install??
any one you want, doesn't need a special one, just make sure you buy a pitman that matches your sector (large or small)
OK, I meant does the Borgeson box use a stock mopar pitman arm or something different..
Per your comment does the borgeson box come with the small and large shaft for the older and newer pitman arms??
Yes it uses the stock pitman arm. Comes in both sizes, small and large sector. Just pick the one you want when ordering.
Yes, Dick’s selector support does work with the Borgeson box. I installed one on my ’71 Charger last fall. It bolted up just as if it were connected to a stock Mopar steering box.
Michael Roberge
'71 Charger R/T
440 4bbl, 500HP/500Ftlb
Best ET: 11.590 120MPH
