Well my junk is single 4, cast intake that is unported.
I am sure the experts will tell you that my on track numbers dont bear out the dyno numbers. 2875lbs 8.0's at 169 and change from 525" of B1. With the stop on it set up for S/ST, with that convertor we have been 8.teens at 165. Would love to hear what the experts think it should run with a dynoed 1050hp.
FWIW 1000hp in a 1750lb dragster should be able to go 7.0's at close to 190
