I mocked up the radiator before i welded the front back together. You can never be sure too much!!!
Welded and Removed...
Then i proceeded to mount the fenders for the first time to keep everything in line as i proceeds through the resto....
Now that the front end is basically done, i moved into the middle of the car which is by for the worst area due to the degree of rust. I Removed the roof...
