Well got everything back in the car and started it. Ran in the shop for a good 10 minutes. Never reached half way on the temp gauge. Watched the burp tank and it appeared there is flow in there. Checked the inlet and outlet hoses on it and they both were warm. So that tell me the water pump should be ok. Felt the top hose and it was warm. lower hose was cold. Fans turned on but only the left side on low. Switched the relays out with the auto shut down one. They all were good as the car started with each one in the auto shut down spot. Next I undid the wire connector for the fans. Ran power from my jump box to the 4 terminals one at a time. I could get the drivers side to run both high and low. passenger side at 1st just squeeked. hit on it and it would only turn on low at a very slow speed. So does it sound like a fan replacement issue to anyone?
thanks guys!
corey
