i went thru this on my 65 coronet. i did the governor change stuff, valve bodies, cussing a lot, and guess what? the kickdown linkage was too tight and when everything got hot the kickdown lever wouldn't return to the closed throttle position. otherwise i didn't have a downshift at a stop. look at this carefully before you get into the tranny again.
