Re: Has anyone braced a K-frame in the car?
[Re: jcc]
#1155341
07/23/12 02:24 AM
07/23/12 02:24 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Any installed pics?
I'll have one of the sector support kit by the end of the week. (It's kind of handy having Firm Feel less than a mile away.)
And the purpose, if I understand it correctly, is to prevent "flexing" of the 1.25"? sector shaft, to lighten the load on the OEM sector bearings, AND to basically supply another mounting point for the PS box? I can't imagine shaft has much relative flex in the scheme of things.
If you take a look at the FSM, it is plainly obvious that the design of the steering gears does not plan for very high steering loads. The "cross shaft", or what we have have been referring to as the sector shaft, has ONE bearing supporting the load. Mainly, it appears that the bearing is to precisely locate the cross shaft w.r.t. the worm (input) shaft. The bottom end is held mainly by the housing, seal, and dust boot.
The "flex" in the steering system is a combination of (a) sector shaft flex, which admittedly is likely small, (b) housing flex, also probably fairly small, and K-frame steering gear mount point flex, which probably is the majority.
I see the sector support kit as having a two-fold purpose: (1) reducing the flex of the above mentioned elements, and (2) reducing the stress and wear on the steering gear housing at the lower end from the loads on the sector shaft.
We've all driven late-model cars - even my '86 Supra is still better than the RR in the handling department - why not help our vintage iron as much as possible with the tech improvements?
