Quote: larry looks like it coming along nicely,what did you decide on for a K-frame? 63-65 or later 66-70 V8?
Hi Bill! Haven't heard from you in a while. You bring up a great thought I'd not considered yet- K frame swap. Will a 65 fit as I've still got that smashed Satellite out back. For some reason I thought they were different, but maybe it's the different V8 mounts that threw me off.
Mine had a '65 B/383" K member in it...switched from a /6. I used the stock type mounts with elephant ears.
If you like drag racing, support your local track.
