Re: Cam changes or not.
[Re: kilroy]
#1131661
12/11/11 04:35 PM
12/11/11 04:35 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
How much tire frying ability ya think Ill gain to be Neanderthalic about it?
Where does your powerband start now? (Whats the lowest RPM that you can roll into the throttle quickly, in gear, without a bog, and have it pull hard).
If its much over about 2500 then I'd say you can gain a LOT!
I have the carb and distb. dialed, I can roll into it at any Rpm, its just not absolute tire frying. I am running 3.55 w/ a 275/60/15 but they are just street tires. I have a homemade caltrac style suspension w/ hd springs so ireally dont think im that stuck to the ground.
Interesting, I have a 70 'Cuda, 440 4speed, 3.55 275/60/15 with caltracs on HD Springs! Lunati 60303 cam (268/274, .493/.513 hydraulic) and I can't trottle under 1900-2000 RPM, but once above that point its an easy burn em as long as you want.
