Quote: I just ordered the B1 package that is posted here on Moparts great deals area. I am having them set the heads up and do the stage 1 port job, bowl blends,
For sure the B1 originals will make good power. And the yearly winter sale is the right time to buy them from Koffels. I will let the guys that have run them tell you about the value of upgrading the porting and rocker gear. And I assume you know the piston valve reliefs will need to be made specifically for these heads.
