Brandon Fugler's 69 Camero 4.48 @ 169 3100 lbs Leaf springs No anti roll bar Naiser built 622 Mfi on alcohol/Procharger 315 radials without beadlocks
now, where are the guys that say you must have lots of front suspension travel for a Caltrack car to work!
John look at a camaro real close to sometime.They have 3 sparkplugs behind the spindle where mopar has three in front of the spindle.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
