here are the two steel patches. The one on the right is the outer handle surround. The piece on the left is the still unbent edge/inner panel. On the edge panel, notice the shape outlined in marker, and the 3 places the screw holes will be. The angled slot like marking will be for the door latch adjustment. This is a new piece of sheet metal with a slight surface rust that will sand off.
