On the crank sensor issue I have notched a couple '91 cases for a '93 Dakota. Not too hard with a die grinder.
I shouldn't have to notch anything if I use a 1995 46RH, right? If I keep my 727 I would need to, but I want OD!
Nope just bolt it in and go. '92 318s (and '93 360s) were Magnums and were notched from then on up for the crank sensor. So yeah your '95 tranny should be fine.
For really wierdness there ARE notched 904/998s I have one in my '95 Van and I know of a '98 that has one as well.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
