did u retorque ur head bolts. i retorque them the next day. loosen one & torque it in sequence. 11-1, pump gas. never had a leak. using the same gasket as u are. some will say that isn't necessary, but i have no leaks. using the same gasket as u are. stay safe, seeya.
