Did it blow #5 into the lifter valley? I had this problem on my blown 340. The culprit,detonation. Went thru a few sets of pistons and head gaskets. Then I discovered it had too much total timing for my combo. Pulled out 5 degrees. Same gaskets since 1991.
Doug
