Hello. Have been reading in the Moparts archives about the best tranny pan gasket to use. Have already made sure leak is NOT from higher up, its at the pan. I bought the extra deep steel tranny pan from Mopar and have already tried various gaskets but no luck. I was then reading about the anti crush gasket offered by Chrysler dealers. My biggest concern with that gasket is about how much torque do I apply so I won't strip out the bolt threads of the transmission? I noticed alot of caution concerning this gasket because it was thicker than normal.
I know the shop manual states to torque the bolts 150 inch lbs but what would I torque the bolts for this gasket?
