5.7 head gaskets have a right and left side 6.1 head gaskets use the same gasket
now, put a 5.7 eagle head on a 6.1, what head gasket do you use?
I'm thinking the 6.1 because of the bore but why does the 5.7 use a left and right? Is it because the 6.1 doesn't use the EGR?
IDK! i have yet to figure out why they would make a right and left head
the 5.7 has a right & left head because an egr passage runs thru the front of the head on the right side.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
