Check the pan to see if it is dented.A cracked filter or fluid level will cause the same problem.Does it delay while going into reverse or forward?After the repair was the transmission quick learned?The codes are telling you its not engaging according to the speed sensors.Loss of prime,like a 727 after it sits a week.
