lets say i can get the car down to about 2500lbs less hp will i still be in for a cracked block?????
How much do you think you will spend taking 700 lbs off your car? The aftermarket block is worth every penny you'll spend on it, but if you HAVE to use a stock block I'd suggest a low block over an RB.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
