Anything is possible, provided you have the money and intestinal fortitude to see it through. IMO biggest bore you can tolerate(aftermarket block)and stroke to get you where you need to be. Be prepared to by valvtrain pieces from time to time as you are gonna need to see A LOT of RPM to make it happen. Gonna need the bore size to unshroud the valve.
IMO a SMALLBLOCK of those cubes may be a MUCH better way to go. The BB heads out there are not built to make power with the small bore you are asking about. Kinda why the guys at the top of the aforementioned classes are running smallblocks not bb....Just my
