New Summit Racing Gen 3 Hemi Heads #3274831
12/08/24 04:25 PM
12/08/24 04:25 PM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
I just came across this information accidently. EngineBuilder web sight published this information on December 5th, 2024. Here's the posting: https://www.enginebuildermag.com/20...on-cast-cylinder-heads-for-gen-iii-hemi/
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274912
12/08/24 09:41 PM
12/08/24 09:41 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
Says they are "final assembled in US" so they are made in china... better be a couple hundred a pair if they want to compete with stock castings.
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274913
12/08/24 09:47 PM
12/08/24 09:47 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
Oh I found em, they are in stock ($2900 a pair)... they are more money than the AFR that is already over priced. I'll stick with BGEs.
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274915
12/08/24 09:48 PM
12/08/24 09:48 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
Actually comparing pictures it looks like the exact same casting as an AFR
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3274968
12/09/24 08:55 AM
12/09/24 08:55 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2.125 intake valve, 6.4 has 2.14
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3275336
12/10/24 06:36 PM
12/10/24 06:36 PM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
BINGO, Same head as the AFR Street Hawk. 2.05/1.59 valve
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3277408
12/21/24 09:32 AM
12/21/24 09:32 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
It probably is. I believe the new AFR LA heads are Chinese castings as well.
That all said, these Chinese castings are better quality than Edelbrock stuff I have seen recently. So there is that.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
