Re: New Summit Racing Gen 3 Hemi Heads
[Re: Wailin D]
#3274912
12/08/24 10:41 PM
12/08/24 10:41 PM
Posts: 12,584 Kalispell Mt.
HotRodDave
Kalispell Mt.
Says they are "final assembled in US" so they are made in china... better be a couple hundred a pair if they want to compete with stock castings.
[Re: Wailin D]
#3274913
12/08/24 10:47 PM
12/08/24 10:47 PM
HotRodDave
Kalispell Mt.
Oh I found em, they are in stock ($2900 a pair)... they are more money than the AFR that is already over priced. I'll stick with BGEs.
[Re: Wailin D]
#3274915
12/08/24 10:48 PM
12/08/24 10:48 PM
HotRodDave
Kalispell Mt.
Actually comparing pictures it looks like the exact same casting as an AFR
[Re: HotRodDave]
#3274968
12/09/24 09:55 AM
12/09/24 09:55 AM
Posts: 2,952 Pattison Texas
CSK
Pattison Texas
2.125 intake valve, 6.4 has 2.14
[Re: HotRodDave]
#3275336
12/10/24 07:36 PM
12/10/24 07:36 PM
Posts: 46 Quakertown PA
Tay
Quakertown PA
it looks like the exact same casting as an AFR BINGO, Same head as the AFR Street Hawk. 2.05/1.59 valve
[Re: HotRodDave]
#3277408
12/21/24 10:32 AM
12/21/24 10:32 AM
Posts: 11,843 Portage,michigan
B3422W5
Portage,michigan
Actually comparing pictures it looks like the exact same casting as an AFR It probably is. I believe the new AFR LA heads are Chinese castings as well. That all said, these Chinese castings are better quality than Edelbrock stuff I have seen recently. So there is that.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot 6.52 @ 105.20
