New Summit Racing Gen 3 Hemi Heads #3274831
12/08/24 04:25 PM
12/08/24 04:25 PM
Southern Missouri
Wailin D Offline OP
Wailin D  Offline OP
Southern Missouri
I just came across this information accidently. EngineBuilder web sight published this information on December 5th, 2024. Here's the posting: https://www.enginebuildermag.com/20...on-cast-cylinder-heads-for-gen-iii-hemi/
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274912
12/08/24 09:41 PM
12/08/24 09:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Says they are "final assembled in US" so they are made in china... better be a couple hundred a pair if they want to compete with stock castings.
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274913
12/08/24 09:47 PM
12/08/24 09:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Oh I found em, they are in stock ($2900 a pair)... they are more money than the AFR that is already over priced. I'll stick with BGEs.
Re: New Summit Racing Gen 3 Hemi Heads [Re: Wailin D] #3274915
12/08/24 09:48 PM
12/08/24 09:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Actually comparing pictures it looks like the exact same casting as an AFR
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3274968
12/09/24 08:55 AM
12/09/24 08:55 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2.125 intake valve, 6.4 has 2.14
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3275336
12/10/24 06:36 PM
12/10/24 06:36 PM
Quakertown PA
Tay Offline
Tay  Offline
Quakertown PA
BINGO, Same head as the AFR Street Hawk. 2.05/1.59 valve
Re: New Summit Racing Gen 3 Hemi Heads [Re: HotRodDave] #3277408
12/21/24 09:32 AM
12/21/24 09:32 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It probably is. I believe the new AFR LA heads are Chinese castings as well.
That all said, these Chinese castings are better quality than Edelbrock stuff I have seen recently. So there is that.
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
