Re: Todd Goodwin’s Latest [Re: MRE] #3230286
04/30/24 04:50 PM
04/30/24 04:50 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by MRE
Regarding "pump gas" B1, dynoed my 572cid B1 with 10.2:1 comp 285/294dur .750"lift camshaft last summer made 870hp on pumpgas
Excellent numbers! What induction do you have?
Re: Todd Goodwin’s Latest [Re: Cab_Burge] #3230295
04/30/24 05:20 PM
04/30/24 05:20 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by Cab_Burge
I called a dyno shop in the Medord,OR area to schedule some engine testing and tuning, one SB Ford Windsor pump gas 387 C.I. street motor with EFI for a good customer and my 572 C.I. KB street wedge bock 4.5x4.5 with a set of B1 heads with 15.02 to 1 comp. ratio for E85 fuel and a sheet metal tunnel ram using a pair of Mark Sullens E85 Dominators.
It will be a couple of weeks before my motors can go on that dyno due to other customers already schedule in front of me shruggy
I'm hoping to make close to 400 HP on the Ford Motor and close to or over 1000 HP on the B1 motor on E85 luck
i bought a bunch used B1 parts years ago and I'm hoping they work well together luck realcrazy shruggy
Cab, i am expecting you to be pleasantly surprised, in a good way. I put my bet on 1,000+ hp for your b1 572
Re: Todd Goodwin’s Latest [Re: MRE] #3230312
04/30/24 07:06 PM
04/30/24 07:06 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Good power, I sent UEM an email today about pistons for a 10:1-11:1 528 for B1's, see what they come back with.
Edit-nothing for a 4.375 stroke, so it would have to be a 4.250 or 4.5 engine.
Re: Todd Goodwin’s Latest [Re: Uberpube] #3230357
04/30/24 09:53 PM
04/30/24 09:53 PM
gregsdart Offline
gregsdart  Offline
Molnar makes a 7.0 ling heavy duty H beam, with a cometic .027 gasket and a piston for 4.25 stroke it might get you close enough. What about changing pin height on a piston order? Last option, use the 4,5 stroke piston and a custom aluminum rod.
Re: Todd Goodwin’s Latest [Re: gregsdart] #3230636
05/02/24 12:27 PM
05/02/24 12:27 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
This seems like an awful lot for an MC motor..
Having had BES build me an original motor and talk about MC's with 70 more cubes I still don't think we would hit those numbers. Goodwin builds some badass motors, but scratching my head on this one.
Where is Al? lol
Casey FJ
Re: Todd Goodwin’s Latest [Re: Whompin_Wedge] #3230652
05/02/24 01:28 PM
05/02/24 01:28 PM
WI
mopar873 Offline
mopar873  Offline
WI
Yeah, I've been waiting for Al to chime in too, as he is used to playing with high end heads. I keep focusing on two things.....530" and an actual power peak of 8500 and I'm willing to bet it holds pretty hard for several hundred rpm after that. Those heads are pretty serious to print #s like that, would love to see them up close.
Re: Todd Goodwin’s Latest [Re: mopar873] #3230702
05/02/24 07:40 PM
05/02/24 07:40 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Alan Jones
Re: Todd Goodwin’s Latest [Re: LA360] #3230761
05/03/24 08:06 AM
05/03/24 08:06 AM
COLUMBUS, OH
W
W
COLUMBUS, OH
Yea, the PSO heads are awesome.
This build mentioned is utilizing the MC heads though. I could maybe see it in a PSO motor wingin it to the moon.
Thanks,
Casey FJ
Re: Todd Goodwin’s Latest [Re: Whompin_Wedge] #3230781
05/03/24 09:32 AM
05/03/24 09:32 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Where is Al? lol
Casey FJ
BES has built B1 engines that make over 1100 up
....BAD A$$ STREET CAR.....
Re: Todd Goodwin’s Latest [Re: n20mstr] #3230834
05/03/24 04:11 PM
05/03/24 04:11 PM
COLUMBUS, OH
W
W
COLUMBUS, OH
Where is Al? lol
Casey FJ
Yep! I know first hand.
Casey FJ
Re: Todd Goodwin’s Latest [Re: Whompin_Wedge] #3231222
05/05/24 07:48 PM
05/05/24 07:48 PM
LA360 Offline
LA360  Offline
Yeah sorrry, I read the original post on my phone, don't mind me!
Thanks,
Casey FJ
Alan Jones
Re: Todd Goodwin’s Latest [Re: LA360] #3231238
05/05/24 08:54 PM
05/05/24 08:54 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
So if it's not about class rules, numbers matching or chassis limitations, at what point do you go Gen II hemi over B1? Probably the cost isn't that much different in the end?
Re: Todd Goodwin’s Latest [Re: Uberpube] #3231256
05/05/24 09:59 PM
05/05/24 09:59 PM
The b1 was develop to replace the gen 2, correct? work scope grin shruggy
My next all out high HP build will be a B1 MC supercharged (25 to 35 lbs. boosts luck) EFI on E 85 555 C.I. Koleno high nickel block luck boogie up Shooting for and hoping for 2500 HP +
Re: Todd Goodwin’s Latest [Re: Cab_Burge] #3231299
05/06/24 08:49 AM
05/06/24 08:49 AM
Out of the State of Confusion
blue_stocker Offline
Cab, where are taking your engines to, Bullet Racing in Central Point? I had them do some dyno work for me and the owner knows his stuff pretty well...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Todd Goodwin’s Latest [Re: Uberpube] #3231532
05/07/24 09:14 AM
05/07/24 09:14 AM
gregsdart Offline
gregsdart  Offline
The B1 mc heads, from what i have read, produce better power per$$ spent, so it becomes a choice of what you like.
Re: Todd Goodwin’s Latest [Re: gregsdart] #3231719
05/08/24 12:06 PM
05/08/24 12:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Put it in a car run it down the track and cross the scales and then get back tome....And MC head is plenty capable of 1100, we did it at 525". Those numbers as with others I've seen from Goodwin are pie in the sky. I have seen one of his 5.0" BS Hemi deals come FAR short of his advertised numbers on a dyno..Maybe I could put up a video claiming I made 1400 does that make it so..
Re: Todd Goodwin’s Latest [Re: Uberpube] #3231721
05/08/24 12:07 PM
05/08/24 12:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Thats easy, NEVER in the NA world.
Re: Todd Goodwin’s Latest [Re: Al_Alguire] #3232118
05/10/24 09:38 PM
05/10/24 09:38 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Is that because the piston dome shape of the Hemi hurts power?
