Re: Differences between B1 original and PSO
[Re: sgcuda]
#2414157
12/06/17 01:21 PM
12/06/17 01:21 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Those are some really nice looking heads!!
No help to the OP...... Never had a set in my hands.
[Re: tjmarcus1]
#2414202
12/06/17 02:35 PM
12/06/17 02:35 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Any dyno numbers! any specs on engine! 588" nitrous deal with lots of quench & softened chambers along with lower compression...900" 55mm nitrous cam,Etc,Etc !! Made 1100ish and was strong thru out the rpm band...My engine guy who is a NHRA comp elimator record holder and many time national & divisional winner was very happy as he felt we are leaving around 150hp on the table being a built for nitrous !! We race a Limited jet 275 radial class and should be around 4.60-4.70 range with a .040 jet @ 3250#
[Re: sgcuda]
#2414216
12/06/17 02:54 PM
12/06/17 02:54 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Would imagine Self is doing his own heads, but I have seen the Slawko CNC versions and they look similar. Good stuff for sure. Slawko will have a CNC Predator program soon as well.
[Re: WO23Coronet]
#2414383
12/06/17 09:11 PM
12/06/17 09:11 PM
Gary Robbins
Idabel,Oklahoma
And what exactly does "softening the chambers" mean? Hard to tell in a pic...If you look at the difference in color in the chamber it's where they cut a small scallop on both sides to help in use of nitrous !! Al is right both ways...Slawko cnc'd and Kevin Self hand finished ..Rare for Self to go behind someone but Slawko has a cnc program that got us way ahead in the game !!
