Rear Pinion Seal
#2791996
07/02/20 07:18 PM
07/02/20 07:18 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hello. What are the steps to replacing a rear pinion seal on a Dana rear of a 1970 Plymouth GTX? What kind if gear oil do I need to put in it? What gear oil for a 4 speed transmission? TY for any help!
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Rear Pinion Seal
[Re: GTXKARL]
#2792106
07/02/20 11:08 PM
07/02/20 11:08 PM
Posts: 43,124 Bend,OR USA
I use a big pipe wrench on the pinion yoke, tighten it up so it holds well and then use 1/2 inch or if you can a 3/4 inch breaker and socket to break the pinion nut loose. I use a brass drift, punch, to drive the pinion yoke off of the pinion shaft as far lube I like and use 75x90Wt non synthetic gear oil with a posi additive for the posi units On the 4 speed look for Pennzoil synchromesh gear oil and use it Summit and probably other hi Po warehouses stock and sell it if you can't find it locally like me
[Re: fastmark]
#2792253
07/03/20 10:33 AM
07/03/20 10:33 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Here is how I break mine loose, it keeps from damaging the gears with an impac
[Re: CSK]
#2792266
07/03/20 11:00 AM
07/03/20 11:00 AM
Posts: 6,225 nowhere
Sniper
nowhere
That's called working smarter, not harder. Here is how I break mine loose, it keeps from damaging the gears with an impact
[Re: GTXKARL]
#2792287
07/03/20 11:35 AM
07/03/20 11:35 AM
Posts: 30,995 Oregon
AndyF
Hello. What are the steps to replacing a rear pinion seal on a Dana rear of a 1970 Plymouth GTX? What kind if gear oil do I need to put in it? What gear oil for a 4 speed transmission? TY for any help! Mancini has the adapter for the yoke. You'll still need a 3/4 breaker bar to fit in the tool and then a big socket and a big breaker bar for the nut. Then you'll need a big torque wrench to tighten the nut back up. https://www.manciniracing.com/yoinreto.html
[Re: Neil]
#2792342
07/03/20 01:59 PM
07/03/20 01:59 PM
Posts: 3,069 Michigan
A727Tflite
FWIW I was told by a guy at a differential shop that occasionally pinion seal leaks can also be from oil migrating down the pinion gear, thru the splines, and out between the washer and or pinion nut. Once everything is wet with oil it's hard to tell where it's coming from exactly. True, and this also applies to the crank bolt and washer. Always use a dab of RTV on the yolk splines and most of the times on the damper slot for the key. I think we even issued an ASN in the early 80’s for the 318/360 damper leaks.
