Rear Pinion Seal #2791996
07/02/20 07:18 PM
07/02/20 07:18 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hello. What are the steps to replacing a rear pinion seal on a Dana rear of a 1970 Plymouth GTX? What kind if gear oil do I need to put in it? What gear oil for a 4 speed transmission? TY for any help!
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Rear Pinion Seal [Re: GTXKARL] #2792037
07/02/20 08:58 PM
07/02/20 08:58 PM
AndyF Offline
AndyF  Offline
That job is easy if you have the right tools. If you don't have the right tools then all you can do is lay under the car and stare at it. The torque on the pinion nut is around 250 ft-lbs so you need a big cheater bar or a big impact wrench. You'll also need a way to hold the pinion. Once you pull the pinion yoke off (takes another tool) then you just pry the old seal out and install the new seal with the correct installation tool. Then you put it back together. Takes about 20 minutes for a good mechanic with all the right tools and a lift. If you don't have any tools then you can work on it for the rest of time and never finish the job. I'm in the middle of changing the gears in my Dana 60 myself. Here is the tool I used to hold the pinion while I'll removed the nut.
Re: Rear Pinion Seal [Re: GTXKARL] #2792106
07/02/20 11:08 PM
07/02/20 11:08 PM
I use a big pipe wrench on the pinion yoke, tighten it up so it holds well and then use 1/2 inch or if you can a 3/4 inch breaker and socket to break the pinion nut loose. I use a brass drift, punch, to drive the pinion yoke off of the pinion shaft hammer
as far lube I like and use 75x90Wt non synthetic gear oil with a posi additive for the posi units up
On the 4 speed look for Pennzoil synchromesh gear oil and use it up
Summit and probably other hi Po warehouses stock and sell it if you can't find it locally like me scope
Re: Rear Pinion Seal [Re: Cab_Burge] #2792182
07/03/20 07:05 AM
07/03/20 07:05 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I think Andy is a machinist so he has nice tools. I did the pipe wrench thing for years. I final grabbed a piece of scrap 2” angle iron and drilled some holes to bolt on the yoke. I then used a torch to cut out the center slightly to get a socket on the nut. I’ve got a big Matco torque wrench that will go to 250. It was not cheap.
Re: Rear Pinion Seal [Re: fastmark] #2792253
07/03/20 10:33 AM
07/03/20 10:33 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Here is how I break mine loose, it keeps from damaging the gears with an impac
103854713_3112138312178190_8471341047009670912_n.jpg104429837_3112138252178196_3958849205188835337_n.jpg
Re: Rear Pinion Seal [Re: GTXKARL] #2792261
07/03/20 10:51 AM
07/03/20 10:51 AM
None
71rm23 Offline
71rm23  Offline
None
I just did this in February. I had to take the whole axle out because I had to change the housing, because one tube was leaking(long story). Anyway, AndyF is spot on with his reply. My rear end oil is a Amsoil racing(?) brand that my friend who had rebuilt it. I know it is VERY thick stuff, not sure of the weight tho.
Re: Rear Pinion Seal [Re: CSK] #2792266
07/03/20 11:00 AM
07/03/20 11:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That's called working smarter, not harder.
Originally Posted by csk
Here is how I break mine loose, it keeps from damaging the gears with an impact
Re: Rear Pinion Seal [Re: GTXKARL] #2792287
07/03/20 11:35 AM
07/03/20 11:35 AM
AndyF Offline
AndyF  Offline
Mancini has the adapter for the yoke. You'll still need a 3/4 breaker bar to fit in the tool and then a big socket and a big breaker bar for the nut. Then you'll need a big torque wrench to tighten the nut back up.
https://www.manciniracing.com/yoinreto.html
Re: Rear Pinion Seal [Re: AndyF] #2792308
07/03/20 12:19 PM
07/03/20 12:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mine was fabricated using a broken torsion bar from a Superbird.
Details at https://www.hamtramck-historical.com/NostalgiaAndOldCars.shtml
Re: Rear Pinion Seal [Re: Alaskan_TA] #2792336
07/03/20 01:23 PM
07/03/20 01:23 PM
A727Tflite Offline
A727Tflite  Offline
So the parking brake won’t hold the yolk? Just asking, I never tried.
Re: Rear Pinion Seal [Re: A727Tflite] #2792341
07/03/20 01:56 PM
07/03/20 01:56 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
FWIW I was told by a guy at a differential shop that occasionally pinion seal leaks can also be from oil migrating down the pinion gear, thru the splines, and out between the washer and or pinion nut. Once everything is wet with oil it's hard to tell where it's coming from exactly.
Re: Rear Pinion Seal [Re: Neil] #2792342
07/03/20 01:59 PM
07/03/20 01:59 PM
A727Tflite Offline
A727Tflite  Offline
True, and this also applies to the crank bolt and washer. Always use a dab of RTV on the yolk splines and most of the times on the damper slot for the key. I think we even issued an ASN in the early 80’s for the 318/360 damper leaks.
Re: Rear Pinion Seal [Re: GTXKARL] #2792464
07/03/20 10:17 PM
07/03/20 10:17 PM
AndyF Offline
AndyF  Offline
Once you remove the pinion nut you'll need a way to pull the pinion off since it is a slight press fit on the splines. Here is a home made puller that I use but a two jaw puller will also work.
